MAP Sensor Keeps Popping Out
Old 04-05-2013, 10:44 AM
Hotrod God's Avatar
Default MAP Sensor Keeps Popping Out
I have an '01 WS6 with an LSX intake and a D1SC that makes around 8.5 PSI boost. My MAP sensor has popped out or been blown out a couple different times now. Would it hurt to try to use permatex on the grommet around the sensor to try to get it to stay in the hole in the back of the manifold? Obviously I'd be conservative with the amount used and would avoid blocking the hole in the sensor.
Old 04-05-2013, 01:15 PM
Moderator
denmah's Avatar
screw in a npt to barb into the stock hole, then use a rubber hose to go into the map nipple.
Old 04-05-2013, 01:59 PM
Hotrod God's Avatar
Thanks. That sounds like a great idea. Looks like I'll be pulling the manifold this weekend.
Old 04-05-2013, 02:08 PM
Moderator
denmah's Avatar
get one that fits it tight and rtv the threads and blow it in with a drill lol then you are set dude you dont want that **** coming out haha
Old 04-05-2013, 05:49 PM
koolrayz's Avatar
Permatex high tack to glue the gromit
Old 04-05-2013, 08:08 PM
theoneeyedbandit's Avatar
On my buddies D1SC 370 we just pulled the old seal off the map sensor and used some vacuum hose on the map sensors nipple and shoved it in there.
Old 04-05-2013, 09:34 PM
robsquikz28's Avatar
I have see it installed with right stuff and zip tied!!!!
Old 04-05-2013, 10:40 PM
Moderator
denmah's Avatar
i cant believe people will put glue all over that shitty tie down map and wont just add a barb lol
Old 04-06-2013, 06:07 AM
LS1Tech Sponsor
Slowhawk's Avatar
Barb as said above. Pretty simple and permanent.
Old 04-06-2013, 12:37 PM
Boosted Firehawk's Avatar
1/8" npt to 1/8" barb?
Old 04-06-2013, 05:07 PM
2000RATA's Avatar
I did the 1/4 NPT to 1/8 barb trick to. Works perfect. I did have to start the threads with a tap first though. I read here you could just thread it in but that was not the case for me.
Old 04-08-2013, 12:16 AM
Hotrod God's Avatar
It did come out while I was driving down the highway. I couldn't figure out why the vacuum dropped from about 10 to 5 and the wide band was going crazy fluctuating from 12 to 17. It wouldn't idol very well either. What kind of bad things should I be on the look out for under the hood after driving it like that? I have an SD tune on it now, so it really needs that map to be working all the time.
Old 04-08-2013, 05:27 AM
SMOKNSS's Avatar
Red face
This is what I have always done. No problems to date on any of my stuff.
Quick Reply: MAP Sensor Keeps Popping Out
