new clutch and flywheel now hard to get in gear
hey guys i just upgraded to a diamond stage 3 clutch and flywheel kit and now after install its really hard to put the car into first or reverse. think it's the master cyl? still on a stock master cyl...
do you think that's the problem though? i dont think the clutch was installed wrong becasue it goes into the other gears like butter and i know the tranny is in good shape so im guessing there's not enough pressure with the stock master cyl?? idk if that even makes sense...becasue it only happens in the gears that your going from a stop haha
Yea had same problem with mine it was engaging close to the floor after replacement and did that mod works really well it's really unbelievable How much of a difference it made
