What is this part?
What is this part?
I'm referring to the split rubber hose in the picture.
Is there a part number for this or should I just measure it and buy a replacement rubber piece?
Thanks
https://dl.dropbox.com/u/24245186/IMAG0650_1.jpg
Thanks
Secondary AIR injection. If you go to shoebox he has diagrams of it. Im sure a piece the same length will be just fine. Or you could get real crazy and remove the system and plug it. Cant remember if you need to have your pcm flashed for that. I know you do if you remove egr and air.
I'd do what fox is saying if your state allows it, though for some reason I don't think it will light the ses light on the 94. I'm pretty sure when I did this to my 94 a few years back it didn't.
....Is there a part number for this or should I just measure it and buy a replacement rubber piece?
Thanks
Thanks
