LT4 Knock Module
Old 04-06-2013, 06:03 PM
jrwilliams95z28's Avatar
Default LT4 Knock Module
Hi does anyone have one for sale or know of a dealer still selling them?
I cant seem to find one.
Are any later knock modules compatible with obd1 PCM's?
I really want to eliminate the false knock im getting at 4400rpm.
Old 04-06-2013, 07:47 PM
F0x Slaughter's Avatar
You don't have headers or really anything that will cause false knock.
How do you know you are getting knock? Datalogging?
You can de-sensitize the stock module with tuning.
Old 04-07-2013, 01:08 AM
rich5368's Avatar
^^ what he said. My tuner desensitized my stock sensor so I didn't need the LT4. Works like a champ.
Old 04-07-2013, 02:38 AM
pboxfun's Avatar
Heres a few sites I found searching google.
http://www.ws6project.com/user_stor/...oducts_id=1284
ACDelco 216-67 Control Module Kit : Amazon.com : Automotive ACDelco 216-67 Control Module Kit : Amazon.com : Automotive
http://www.jcwhitney.com/ac-delco-oe...=d50282y1996j1
http://www.autopartswarehouse.com/sk...cid=productads
http://www.ebay.com/itm/ACDELCO-OE-SERVICE-216-67-Ignition-Module-Control-Unit-/190802048501?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6cb035f5&vxp=mtr
http://www.ebay.com/itm/ACDELCO-OE-SERVICE-216-67-Ignition-Module-Control-Unit-/140939104599?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d0a01157&vxp=mtr
Old 04-07-2013, 06:02 PM
Thanks! I know its false knock because its consistently at the same RPM and it does'nt build up any higher. Also I desensitized the knock sensor but it still picks it up a bit its just annoying really. The timing is set pretty tame at WOT,im around 30* in the 4000-4500rpm range and 33-34 in the 5000+ area and I run 94 octane gas always.
Old 04-07-2013, 06:23 PM
Turn off the Burst Knock.
Old 04-07-2013, 07:04 PM
burst knock table has been zeroed. max knock retard was set to 5*, I doubled the restore rate and halfed the removal rate. still knocks a bit at 4400ish
Old 04-07-2013, 07:36 PM
Did you zero out the Low Octane tables?
What will happen is if it picks up the false knock then it automatically jumps to the Low Octane tables, be sure not to run low octane then. If you tune it for 91 - 93 do no run any lower.
Old 04-07-2013, 09:21 PM
Oh really? I haven't touched those tables because of a lack knowledge about what those numbers mean, but that's a good idea! So how should I go about it just 0 all the low octane tables?? I always run 94 octane there's lots of Petro Canada stations around southern Ontario. Thanks for the help!
Old 04-07-2013, 09:31 PM
Yes, the Low Octane tables are for if the PCM picks up knock multiple times it then assumes its bad gas so it reverts to the Low Octane tables.
As I said do not run low octane if you do zero these tables as it will have nothing to revert to and ping to death.
Old 04-08-2013, 08:55 AM
Yes I understand the risks, as I said the car since I've owned it (4 years) has never seen gas less than ultra 94 octane from Petro Canada. Since I've tuned it I've only been more diligent in making sure I put 94 in.
So all low octance tables should be set to 0?
Old 04-08-2013, 04:16 PM
Correct there is no need for the low octane tables if you only run 91+ gas.
Old 04-08-2013, 05:43 PM
awesome thanks I appreciate the help!
Old 04-08-2013, 06:51 PM
Let me know if that clears up your false knock.
I talked to Solomon when I was chasing my false knock and figured it out, I am trying to remember what I did. I know that was one of the things.
Old 04-08-2013, 07:03 PM
moehorsepower's Avatar
why do you say the false knock is annoying? are you constantly data logging all the time you are driving? So you are saying if you do not see it on the data logger then its ok, or is there some actual pinging going on..
Old 04-12-2013, 02:31 PM
boomer50's Avatar
Default LT 4 Knock Module
I got mine from Summit, site says unavailable. If you call tech line they should know if it's still available.
http://www.summitracing.com/parts/ACF-16214681/
http://www.summitracing.com/customerservice
Or, google this ACDelco Knock Sensor Modules 16214681
Old 04-12-2013, 07:29 PM
Toronto LT1's Avatar
I got my LT4 km from a local dealership here in Mississauga (Applewood Chev,Olds).
Old 01-02-2014, 03:10 PM
s-10fan262's Avatar
summit says no lt4 knock modules just checked
Old 01-03-2014, 01:17 PM
am_muscl's Avatar
would it be safe to assume an lt4 knock module would be in any 96-97 lt1?
Old 01-03-2014, 05:55 PM
97Z28SS's Avatar
Only in the LT4 powered 96 Corvettes and 100 LT4 powered 97 SS.
Quick Reply: LT4 Knock Module
