2000 Trans Am Convertible Stereo
Old 04-07-2013, 08:44 AM
mthake's Avatar
Default 2000 Trans Am Convertible Stereo
[IMG][/IMG]
It's not even a Monsoon! The factory Stereo in my Convertible is terrible. I want to keep it as stock as possible.
Is there any way to upgrade while not changing the audio characteristics of a stock stereo. Such as the Monsoon or Bose?
Old 04-07-2013, 08:46 AM
mthake's Avatar
[IMG][/IMG]
You can see the rear speaker location, not many options available here..
Old 04-07-2013, 10:37 AM
Avaric3's Avatar
You don't want to change the "audio characteristics of the stock stereo"?
Then don't change the stock stereo...
What exactly is it that you don't like and wut parts do you like?
Old 04-07-2013, 05:40 PM
Ungrounded Moderator
WhiteBird00's Avatar
That car has a Monsoon system. Otherwise, it would not have separate tweeters in the doors. All 2000-2002 Firebird convertibles came with the Monsoon as standard equipment. You will find option code X20 on your door label.
Old 04-07-2013, 06:54 PM
mthake's Avatar
well, that's good news. I guess they just don't have the Monsoon logo on the radio anymore? Are there amps located with the car? I think this car may have had a custom stereo installed previously, and it was removed to sell... I need to investigate to see if its hooked up properly. I do have the X20
Anyways, if that's the case, I'm probably needing new speakers. I cannot turn up the base, as the speakers will start to pop and or vibrate.
And on the previous question. I like to stock appearance, the steering wheel controls, and a good factory stereo sound.
Old 04-08-2013, 07:30 PM
02DroptopZ's Avatar
Google "Kee Audio", they used to be a sponsor here and I think they still are.. They make a very nice quality replacement speaker package specifically for convertibles.
Old 04-08-2013, 09:17 PM
mthake's Avatar
I checked them out and look good. How can I verify that I have a true Monsoon stereo? It says Delco Pontiac, where Monsoon is typically displayed. I just wonder if a cheap replacement was thrown in there to sell it.. not to mention the monsoon amp, where is that located?
Old 04-08-2013, 10:14 PM
02DroptopZ's Avatar
I believe all T/A’s came standard with a Monsoon system. Strangely, I don't think any T/A's had the Monsoon label (same exact unit, just no label).
To find the amp, pop your trunk, remove the spare tire cover (the trunk lining to the right), and take a peek up past your antenna motor. There should be a big black box tucked up there somewhere, I believe they all say DELCO on them in big letters.
Old 04-09-2013, 08:06 PM
mthake's Avatar
Found it! So, with the amp in place, and the unmarked radio, I'm assuming I have the Monsoon system.
So, let me ask the professionals. When I put in on the rear speakers, they sound decent, but no base, only mids and highs.
When I put it on the fronts, there is too much base, and they rattle something fierce. Sounds as if their blown.
Let me add, there is some evidence of a high end stereo. there are holes in the rear trunk floor (4 for an amp bolted down) Some additional grommets in the firewall, and some suspect grounding screws...
any thoughts?
Old 04-09-2013, 10:32 PM
02DroptopZ's Avatar
That sounds typical for a worn out monsoon system. The rear speakers on a vert are crap to begin with, and blowing front speakers in these cars is very common.. Just more of a reason to upgrade to some quality stuff
Old 04-10-2013, 05:24 AM
Avaric3's Avatar
any thoughts?
that makes your life so much easier cuz running your power wire for an amp through the firewall is the most annoying part of the install aside from general wiring
Old 04-10-2013, 07:16 PM
mthake's Avatar
I'm gonna bite the bullet, this thing is too nice not to have a good sounding stereo. So, what is the recommendation? I'm not good with the ohm thing. But I do know that standard speakers sound like crap on a stock stereo...
Would factory replacements be a mistake?
will GM Bose speakers be an option?
Last edited by WhiteBird00; 04-11-2013 at 08:49 AM. Reason: Merge consecutive posts
Old 04-11-2013, 02:00 AM
99Bluz28's Avatar
I'd do the Kee Audio CDT speaker upgrade, if you're staying with the factory stereo.
Old 04-11-2013, 08:33 PM
mthake's Avatar
Just ordered the Kee Audio Level 2 Convertible package. Can't wait!
Old 04-17-2013, 07:12 PM
mthake's Avatar
Does anyone know how long shipping takes? I still haven't received the speakers...
Old 04-17-2013, 10:54 PM
Sladester2's Avatar
My T/a monsoon does say monsoon on it btw
Old 04-17-2013, 11:06 PM
baalic's Avatar
I thought mine did as well but I could be wrong, mines an 02
Old 04-20-2013, 09:36 AM
mthake's Avatar
Thanks for your comments. I received the speakers yesterday and will be installing them today,, can't wait!
As for the Monsoon thing. Whether or not it says monsoon on the stereo, would it really matter? I'm thinking that monsoon label just depicted the monsoon amp in the car, which I have. As well, it depicted the component speakers on the doors... Just a thought.
Old 04-20-2013, 02:54 PM
Daniel Richards's Avatar
my understanding is the internals of the factory HU are the same regardless of whether it's a monsoon or regular, the difference is where the wires run to.
Old 04-20-2013, 04:37 PM
mthake's Avatar
That's what I was thinking as well.
I got the speakers installed. The system was factory stock, with no butchered wiring.
I gotta say, I'm not that pleased. The Base is too harsh, it sounds like someone's hitting the car with the palm of their hand. I turn the eq down, and it sounds better. The driver side speaker sounds like there's loose change in the door panel. Is there something I'm missing?
I wired it pretty darn good. All factory connections were soldered onto the new speakers connections. The tweeters were pop riveted in place. Every connection was wired red to + and black to -.
any thoughts?
Quick Reply: 2000 Trans Am Convertible Stereo
