1995 Z28 couple of questions.
Hello all. I have a 1995 Z28 that had sat for 8 years. I had the engine rebuilt and its running great. The air conditioning is not blowing cold so I got a refill from autozone. When I attached it to the fitting on the AC it would not fill. I had the engine running and the AC on max like the directions said. The can feels like it has back pressure from the car. I have done this before on another of my cars and as soon as I hooked it up and pressed the button it filled right up. With the Camaro it feels like its pushing into the can instead. Anyone have any issues with this before? Or could it be the AC pump is not spinning? Thanks.
honestly just take it to a local shop......friend of mine has the A/C tool they have........its awesome it vacuums the system and checks for leaks......re charges and re oils automatically.....and it will monitor high and low side pressure........it will prob cost you 150 to have it done but that's what id do..........how much is it worth to be cool on a hot day? lol
Is the compressor kicking on? With the car running there should be a 100-200 rpm drop when it does. If it does not, you may have to override the pressure switch function by jumpering the compressor with 12V
