how do i dissasemble this part of my t56?
You can use a bearing splitter and a hydraulic press. A big one(splitter). As long as you get four points to touch with sufficient meat overlapping it will come off very easily without any damage. You won't be using the splitter to separate anything but rather a surface to rest the syncro assembly on will the press pushes the shaft.
Just an example.
Just an example.
