Need some advice
Need some advice
Running a 05 crew cab Z71 with duel exhaust and a Eaton M112 magna. The truck is running a 3.4 upper and making roughly 8 pounds of boost at WOT. I did have the truck on a mustang dyno a few months ago and it made good numbers at 370whp and 402tq. This is a stock cam/head 5.3 iron block 4L65 set up and the AFR’s and tune are on the safe side. I have been considering going to long tube headers since I have a small exhaust leak any way but don’t want to spend the money on a tune until I have the time and money to do a few other mods.
What do you guys think.
I think Texas speed has a long tube and Y pipe set up for the trucks, it was pricy when I looked into it due to the 4wd.
Exhaust would wake it up for sure, I would also open up the intake side of the Eaton as well... TB, MAF (if you run one) and the biggest air filter you can fit.
I am running a AFE stage 1 intake with pro guard filter on the intake side with the magna intake pipe. The truck has true duel exhaust on it right now so all I would be changing would be the manifolds and going with the armor coated pacesetters going off what trucks guys have told me.
