What to do with cooling fan on 12 rib Procharger
What is the best cure for the D/S fan with a 12 rib setup? Can I get a slimmer fan for the D/S, just run one fan or what?
You are probably gonna need to stand your radiator up im guessing. I had to with a 8rib setup only because i used a thicker griffin radiator, a small amount of fabrication involved to get my 4" from my FMIC to my TB.
I got it taken care of. I made a piece of angled steel that fit between the radiator bracket and the fan bracket that pulled it 1/4-1/2 inch closer to the radiator. This got me the clearance I needed.
