Trying to decide on a f1-a, f1-c, f1-r and fuel system
We have a 408 317 (flowing 317-318)
ported heads, brute speed cam 80 lbs Siemens Aeromotive boost reference regulator. Waste gated also. 4l80e built and a yank 3600
It will be a street car mainly. It will have all factory options including ac.
I am trying to decide on a blower size.
F1-a
F1-c
And fuel pump 92 octane and meth
Already have filter Aeromotive 10an with shut off
I am thinking 10 an line in 8 return incase we go e85 later
2 or 3 walboro pumps? 255's or 400's
F1-a
F1-c
I would get the new F1X and put a bigger pulley to limit boost. more contact, less slippage. The F1X is easier to turn also, freeing up a little more usable hp.
Also, I have 2 walbro 450's. 2nd pump turned on at 7 psi boost. i am running a little over 1000rwhp.
I had a D-1SC, and had the opportunity to upgrade to an F1C, so I did. My car is a 5.3 truck motor in my 99 Vette and is a 6 speed. I am interested in the wastegate setup you keep mentioning.
F1X has a 5 inch opening, so I really did not have many options. I just used a cast 90 elbow with a 6 inch conial filter. I have a meth nozzle tapped into the elbow also to cool down the head unit air intake, so the head unit would be more effecient. I attached an older picture of my engine bay, but the filter is still in the same location just to give you an idea.
running a boost a pump is not going to help the injectors unless you up the fuel pressure, and even that will only help a little. It really depends on what hp level you are shooting for. F1A would be ok up to 800-850. 80 pound injectors should work fine up to that power level, but will be very close if not maxxed out.
that is a GTO mounting bracket with a custom re-enforcement brace closer to the fender i made.
LS1Tech Sponsor
This is a 408 with 317 heads, boost should be limited to keep the heads from lifting. This car is also to be street driven in the Kansas City area with air conditioning. My vote is to keep it simple and go with an F-1A. 900 rwhp should keep things interesting for you for quite a while. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I do like the gto bracket might do different heads later. I have a coated 3.85 pulley. How far will the 80's go I am thinking the waste gate with a controler would put less stress on my motor and help livability even though more boost earlier. But only on short few occasions would car see high boost to lift heads
LS1Tech Sponsor
__________________
