quick stall question
About to order a stall and was wondering if i should go between 4000-4500. Cam and bolt on ls6. Rev limiter around 6800-7000. Gonna be a weekend warrior and a Lil drag strip. Will have lockup. How big should i go? 3.42 gears
I agree with mjs1020. I would run more gear. What type of converter are you looking at? Yank's SS PT series? This is the same situation I just went through. I ended up going with a PT4200 with a pretty big bump stick. The PT has shorter shift extensions compared to the SS. This is why they say not to run n20 with the PT series. Give us a little more info.
You should go to our website FTIPerfomance.com and fill out a build sheet. Then one of our specialists will call you and give you the best advice for your combination.
Thanks,
FTI
Thanks,
FTI
__________________
1-866-726-8358
Some call it cheating we call it the"COMPETITIVE EDGE"
1-866-726-8358
