345 30 19 on TA
Old 04-11-2013, 11:11 AM
Maxx Burkholder's Avatar
Default 345 30 19 on TA
Hey guys. Just finished getting a pair of 345's mounted on a 19x12 set of wheels.
If anyone is thinking of doing it all it required was an 1/2'' spacer, longer studs, and a little time with a hammer.
What do you guys think?
Old 04-11-2013, 11:36 AM
willy9's Avatar
Looks good. About how much hammer time lol?
Old 04-11-2013, 11:55 AM
surprisingly not much at all, just a couple minutes on each side. spacer helped ALOT
Old 04-11-2013, 02:12 PM
willy9's Avatar
Which spacer did you use? Also did you had to cut the bump stops?
Old 04-11-2013, 03:04 PM
ramairetransam's Avatar
better pics please
Old 04-11-2013, 03:12 PM
Rise of the Phoenix's Avatar
Looks good from what I can see. I run a 325/30/20 and all I had to do was do a little hammering.
I guess I don't understand how spacers work. Wouldn't a spacer make the tire stick out more, which would be the opposite of what you are trying to do?
Old 04-11-2013, 03:20 PM
badformulaLS1's Avatar
I've wondered that too.^
Old 04-11-2013, 03:24 PM
redtan's Avatar
He's trying to get clearance inward, so using the spacer to push out the wheels further from the inner wheel wells.
Old 04-11-2013, 08:35 PM
Furious1's Avatar
I think it looks awesome, in for more and better pics!
Old 04-12-2013, 08:52 AM
TA_Moscow's Avatar
Wow. Add more pics!
Old 04-12-2013, 11:07 AM
carlos64030's Avatar
Which in turn makes the wheels and tires stick WAAAAAAY out from under the quarter panels.
Old 04-12-2013, 12:50 PM
redtan's Avatar
Well yeah, but at least he can say he's running 345s out back hella flush style.
Old 04-12-2013, 02:14 PM
dailydriver's Avatar
I'd love to run that size at all four corners, but that would require at least the 'Sunoco Special' flairs/fender bulges, as well as some industrial quality, custom front wheel bearing assemblies.
Old 04-12-2013, 05:54 PM
DemonicZ's Avatar
what offset or backspacing are those 19X12...thinking about getting Forgestar CF5s in 19X10 front and 19X12 rear
Old 04-12-2013, 07:54 PM
well yeah, but at least he can say he's running 345s out back hella NOT flush style.
Fixed
Old 04-12-2013, 11:31 PM
Mr.z/28's Avatar
Definitely want more pics as well.
we need more information!!!
I cant decide whether to run a 19x10 or 19x12 inch wheel out back
Old 04-12-2013, 11:47 PM
69TA's Avatar
he needs the spacer because they are probably Vette offset and have like
a 8.5" backspace
Old 04-13-2013, 01:50 AM
2QuikTA's Avatar
I must be the only one who thinks that looks like *** with the tires sticking out like that.
Old 04-13-2013, 09:26 AM
UGotBeaT's Avatar
probably 59mm offset
Old 04-13-2013, 09:53 AM
Ill get some more pics up for you guys. Like i said all it took was a 1/2in spacer. And yes that does push the wheels out more. And I did not have to cut the bump stop at all. It really didn't take much time at all.
Here is the link to the wheels for backspacing info.
http://www.supervettes.com/oem-c6z06...-polished.html
Wheels are nitto Invo 345/30r/19
Quick Reply: 345 30 19 on TA
