Help fast!!! Car missing In rain!!
Old 04-11-2013, 04:24 PM
jlincks's Avatar
Default Help fast!!! Car missing In rain!!
Ok drove my car in the rain today and now I'm on the side of the road with my ls1 missing. I forgot to tape upy rear o2 sensors when I put my headers in and they are dangling down and soaked. Is that my problem for the missing?
Old 04-12-2013, 07:05 AM
Latch's Avatar
Wet 02 sensors will cause missing. I had 02 sensor extensions on my car and when the connections got wet the car would miss really bad.
Old 04-12-2013, 10:48 AM
jlincks's Avatar
do i need to tape them up?
Old 04-12-2013, 03:00 PM
astro11271984's Avatar
I didn't tape up my rear o2s i would check if your getting moisture in the front ones the rears are just to monitor the cats the front are used to mesure air/fuel
Old 04-12-2013, 10:10 PM
AmarilloWS6's Avatar
When I had my ws6 I ran o2 extensions and everytime they got wet the car missed real bad. I got tired of messing with them and just re-pinned the PCM to where the rear o2 sockets red the front and I could use the nice, factory length o2's and I would never have to deal with missing again.
Old 04-13-2013, 08:07 AM
cyberkill's Avatar
Check for any exposed wires getting wet for your Front O2s.
When I did my O2 extensions after headers, I zip tied them so they wouldn't dangle, but I was either too dumb or too anxious to start driving that I didn't realize a part of the extension was touching some part of the exhaust pipe. Over time, it burned through the heat shielding and burned right through the wire insulation so bare wire was exposed. Everytime I washed the car or it rained, I'd get misfires. When I discovered it, I tested it by keeping the car on, taking a spray bottle, and just spraying a little bit at that exposed wire, and I could immediately hear the engine misfiring.
I just bought the Bosch Corvette Rear O2 sensors to replace the front O2 sensor + extension, and this time ziptied the excess wire more carefully and problem solved.
Old 04-13-2013, 12:30 PM
EricYJ-TA's Avatar
I would try putting some Die Electric grease in the connectors. It may help.
Old 04-13-2013, 10:58 PM
jlincks's Avatar
if its not any of those thing could it be the fuel pump going bad? The car has 150,000 miles on it.
Old 04-14-2013, 10:32 AM
EricYJ-TA's Avatar
Maybe I would hook up a fuel pressure gauge and see where your at.
Quick Reply: Help fast!!! Car missing In rain!!
