what is it worth 02 TA 29k miles
Old 04-11-2013, 07:09 PM
RaM AiR 97's Avatar
Default what is it worth 02 TA 29k miles
I have a 02 pewter trans am ram air with 29k miles. The only reason I will be selling is because I got a real good deal on a house
The good
AFR 205
TM grind cam I believe not sure
Throttle body
Slp air lid
Hooker super comp Lts
Electric cut out
5.0 short throw shifter
The bad
small scratch on pass side fender not noticeable
1/4 inch tear on driver side seat
Can't upload pics sorry
Thanks
Old 04-11-2013, 07:53 PM
RaM AiR 97's Avatar
Clean title btw
Old 04-12-2013, 09:39 AM
NC01TA's Avatar
Overall condition of the car? Good, fair? Need anything like tires, etc...??
Normally a low 29,000 miles '02 T/A would sell for around $14,000 - $15,000 but those mods are really going to hurt, especially an internal engine mod. You call it 'the good' but it is just the opposite. Many potential buyers will be 'put off' and not even respond to the ad. Your car will appeal to the younger male demographic that will appreciate your mods to some degree. Unfortunately this is the market that generally has little cash and will need a loan. Some banks will be reluctant to give that loan which leaves you in an even tougher situation. Even if the car is in good condition and has no needs, I would probably ask around $13,500 and accept the first solid offer that comes along, unless it is just too low for you. If no responses at $13,500, and there may not be, then bring it down to $12,900 or even lower until you get a few calls. If the car has some issues or needs not described, then even lower. Hopefully everything is fine and you will find that certain buyer real quick. GLWS!!
Old 04-13-2013, 05:59 PM
Rated Z's Avatar
The good
AFR 205
Throttle body
Slp air lid
Electric cut out
The bad
Thanks
Is it an m6?
Quick Reply: what is it worth 02 TA 29k miles
