Twin Turbo System for 1998-02 LS1 Camaros & Firebirds
Old 04-12-2013, 11:45 AM
granatelli sales's Avatar
Default Twin Turbo System for 1998-02 LS1 Camaros & Firebirds
Granatelli Twin Turbo System for 1998-02 LS1 Camaros & Firebirds
Granatelli Motor Sports is proud to announce the availability of the Granatelli Twin Turbo system for 1998-02 LS1 Camaros & Firebirds. The system produces 450RWP @ 7 PSI using 91 California grade octane fuel but is capable of 1,100RWP on a professionally built engine. (Recent testing showed 815 rwhp on a low compression 427 LsX engine using 91 California grade octane fuel at 15 psi) The system features near-ZERO turbo lag, instant tire shredding power, superior fit and finish and all OEM quality. The kit is 100% complete, additional engine modifications recommended after 9 PSI (call for details). The kit includes twin 62/66mm PTE6266 T3/T4 housing Precision turbos, twin 38mm TiAL MVS waste gates, Granatelli/TiAL 50mm compressor bypass valve, stainless steel exhaust components through out the system, powder coated tubing from turbo to intercooler and from intercooler to throttle body as well as a large front mount air to air intercooler core. Installation requires only moderate mechanical skills and can be completed within 12 hours. For more information, please call 805-486-6644 or visit www.granatellimotorsports.com.
Old 04-12-2013, 12:34 PM
Blackpanther99's Avatar
Looks like a awesome kit.
Old 04-12-2013, 01:21 PM
93camaro_zzz's Avatar
Do you have an installed picture?
Old 04-12-2013, 02:02 PM
does not come with electric cut out
Old 04-12-2013, 04:08 PM
CaliboyTA's Avatar
do we have to cut a hole on the front bumpers for cooling?
Old 04-15-2013, 12:29 PM
No there is no cutting anything for this turbo kit
Old 04-15-2013, 02:00 PM
Somebody09's Avatar
so what about the FMIC exit, going to the TB? does that flatten or something? maybe i'm not seeing clearly...
Old 04-17-2013, 02:29 PM
yes you are right you will have to cut to get that to fit
Old 04-17-2013, 04:06 PM
87silverbullet's Avatar
What turbo upgrades are available?
Old 04-26-2013, 05:33 PM
the kit comes with journal bearing turbos 6266
but you can upgrade to Ball bearing 6266
Quick Reply: Twin Turbo System for 1998-02 LS1 Camaros & Firebirds
