How much boost can i run at 9.8:1 without meth injection on 93?
Old 04-12-2013, 05:50 PM
703 CAMAROSS's Avatar
Default How much boost can i run at 9.8:1 without meth injection on 93?
Think I can hit 10 Ib's safely? I know allot depends on the tune if it will be safe but do you guys think its possible? It's an AES 390 and s488 turbo. Thanks
Old 04-12-2013, 06:07 PM
93camaro_zzz's Avatar
You should be ok on 10lbs. I ran 9lbs but with only 91octane (California) and I probably could have turned it up a couple of pounds. No meth obviously.
Forgot to mention, I was on 9.06:1 compression.
Old 04-12-2013, 06:10 PM
Preston99WS6's Avatar
Need more info on the setup. For instance is it intercooled, what size injectors ect.
I have ran up to 18 psi on 93 octane with a A/A intercooler and a S480 on 364 ci. 80 lbm injectors and twin GSS340s in the tank.
To answer your questions 10 psi is very safe on 93.
Old 04-12-2013, 06:13 PM
Yes intercooled (A/A) and 180Ib injectors and dual 340lph pump how far you think I could go without meth. I plan on switching to e85 later that's why I'm going overkill on the fuel system
Quick Reply: How much boost can i run at 9.8:1 without meth injection on 93?
