Fun spin around the neighborhood with a quick blast in second.
I was out playing with the GoPro today and decided to roll into second gear and you can hear it just blow the tires off. It was a hit at around 3000rpm. As soon as they started to spin, I short shifted into third, which on the video, there's little to no tire smoke, so maybe once I get the tires heated they'll hook better.
Hopefully when I go back down to the 3.42s, I'll have some more traction.
video isnt working for some reason ?
Says an error, please try later.
And why would anyone say you cant be spinning in 2nd ? I cant get any decent traction until 4th on the street, and even that's on the edge.
edit, working now. Really not much wheelspin at all there, although you just let off ?
Guys, it's a joke. I'm making somewhere around 700rwhp and I know I can't hook 2nd gear on the street, which isn't any big deal or bragging rights or anything like that.
I just got my wheels back from powder coating, and got the GoPro a few weeks ago, so I was just out playing. I've had the discussion before about now being able to hook second gear at all and some people didn't believe me. So it is what it is. A fun ride around the neighborhood on a beautiful spring day.
I was hoping you weren't serious. With making a lot less hp then you, I can short shift spinning 2nd and keep it going through 3rd. They start doing cars and coffee again yet?
Nice to see you out driving the car b$. I remember a month ago J$ posted this video of him blowing em off at 80+ @ 2:15 2009 F1A Corvette 915rwhp/835tq dyno video - YouTube
Motor is broken in. I have about 1200 miles on the motor. I'm debating going to a 3.4" pulley that I have over the 4.00" one I'm currently running. I just need to make sure my fuel system is up to the task.
Yeah, that's what scares me is in 3rd gear, I hook till about 5500-5800 then they break loose which is about 80-90mph. Maybe I'll take a video of that.
QTP longtubes, Kooks Offroad Ypipe, I then have a resonator in the intermediate pipe, I forget who's it is, but it's in the 'how to get rid of drone' thread. Then into a magnaflow catback.
your motors forged now. do it.
True. I'm currently at 15psi at 6900rpm, so I need to step up to a 3-bar map sensor, and then go with 80lb injectors over the 60lb'ers I'm currently running. I'm just wondering if my stock fuel like will support it, and I probably need to run a boost referenced regulator as well.
For now, I'm just going to have fun this spring and summer driving the hell out of it.
I feel you on that. I took my stock lines off a few weekends ago, and they looked a little worse for wear. The swap was simple though. You might as well get 100's just because it wont be that much more money. Lonnie uses fuel lab regs.
I don't think I'm going to max out my pumps with a D1 as Lonnie said dual 255s are good to about 800 or so rwhp. If I max them out, then I'll **** myself for making that much power. Right now I am just not optimized fuel wise to run more boost. With the factory regulator, I essentially lose 15 or more psi of pressure due to the boost, so you compensate by increasing the injector duty cycle to ensure adequate fueling. Well, I'm around 90% injector duty cycle right now with my 60's. So before I go with more boost, I need to either step up to 80s or put in a boost referenced regulator and see where that takes me.
Get sideways at 80-90 is just where it starts getting fun!!! Lol . Sounds to me like u need M/T 275 radials on the back of that thing and it with really be fun
