Waste gate and DP???
Am installing a BW400SX..
1. What's the general consensus on the entry point on the dp for the waste gate? [IE: is there a particular distance from the hsg that works well/better than others?]
2. How does one register the 4" dp split flange onto an opening that's about 3.600 diameter? [This an E-Bag flange] NE1 have a trik piece that would do this??
NE help is appreciated!
This is..
The outboard face is flat w/ the taper on the rear side. The single flange that came w/ the clamp, is supposedly for the S400/T4 hsg. There's no way to register the pipe, so it's centered over the hsg outlet. Unless the pipe side flange is centered when the clamp is tightened, it ends up off location, but tite.
[I guess I could just eyeball it, and then tighten the clamp until it appears centered.]
Hsg outlet has a counter bore that measures 3.60",&.250 deep. The OD of the hsg side flange is 4.62.
The problem w/ that is, the location has to be repeatable in order for the w/g pipe to attach to the dp.
As I understand it, the T6 flanged hsg has the 5"dp, and requires a special v band. Correct?
Thanks for the response.
