On a 98 LS1 Fbody which fuse do I need to pull to disable abs
Like the title says I'm looking to disable my abs because I have 26" fronts and 28" rears. Also if you have pictures that would be awesome because my fuse box covers are faded cause I tried cleaning them once.
Abs is not part of the pcm. It cannot be controlled through standard tuning programs. I believe the bcm controls it and a tech2 is required to alter anything regarding it.
So should I not pull any fuses at all then? I removed my ABS, and the car drives and stops okay, however as soon as my ABS light popped on I got a service vehicle light as well. I pulled a few fuses related to ABS and the AIR systems (I removed that at the same time). Should I replace them?
