Wet or Dry? H/C/I Stroker 100 shot
I have a 404 stroker w/ h/c/i. It has tr-6 plugs, 42 lb greentops, and racetronix fuel kit.
It should be sitting at 550rwhp right now and I plan on doing a 75 or 100 shot.
Do you guys recommend I go wet or dry??
Can you recommend a good realible nozzle??
I can argue both ways. I think the dry would be more reliable and safer but will be pretty much max out my injectors. Also will be a bit trickier to tune initially.
I have all the accessories already and just got a new nitrous controller. I plan on also getting an a/f safety switch.
Anything I am missing?
Can you guys recommend a good wet nozzle for me to use? I used to have a plate but my throttle body and intake are 100 mm now and the old setup won't fit.
http://nitrousoutlet.com/index.php/n...us-nozzle.html
I may have a 100 mm plate in the back that we made and never sold. Ill check into it.
Dave
