Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
AC not working ?
Old 04-16-2013, 10:23 AM
lilgcts-v's Avatar
Default AC not working ?
i let my car sit through the winter and now i have no ac and it seems like i always have warm air coming in the cabin, any idea?
Old 04-16-2013, 11:43 AM
Stone17's Avatar
Is the A/C compressor turning on?
Old 04-16-2013, 04:56 PM
lilgcts-v's Avatar
i honestly didnt even think to check, i thought maybe i didnt have any freon, and are there any proper or better ways to see if it kicks on then the idle dipping down a tiny bit?
Old 04-16-2013, 05:57 PM
RADEoN's Avatar
turn the a/c on, look at the compressor (lowest pulley on passenger side), and pay attention to the center of the pulley, if it spins when the clutch engages, then you have a separate problem, but if it clicks and doesn't rotate, you probably have a bad clutch.
Old 04-16-2013, 06:01 PM
AF_John's Avatar
I had the same issue and it was a bad ground I'm not sure what wire it was the dealer fixed it under warranty. good luck
Old 04-17-2013, 03:23 PM
GM Customer Service's Avatar
If I can assist you to get you’re A/C working in time for the hot summer days, private message me.
Jennifer T,
GM Customer Care Service
Old 04-17-2013, 07:30 PM
1BADCTS's Avatar
LOL, I have the same issue. Going to the dealer in the morning. I just don't have time to mess with it right now.
Old 04-17-2013, 07:49 PM
thefullmonty_07's Avatar
Probably out of freon, I'd just get a bottle and try it, it's only like 20 bucks.
Old 04-17-2013, 09:12 PM
Chrismikeb's Avatar
Freon doesn't just get used up. If its out of freon there is a leak, filling it back up without finding/fixing the leak would be a waste of money.
Old 04-17-2013, 10:36 PM
RADEoN's Avatar
r134a
Old 04-17-2013, 10:54 PM
meatyCTS-V's Avatar
Jennifer T,
Wow, is this for real?
I certainly didn't get this last year when my A/C compressor ate itself alive and started throwing sparks out from under my hood lol
-meaty
Old 04-18-2013, 12:57 PM
lilgcts-v's Avatar
my a/c compressor is working perfectly so i must have a freon leak right ?
Old 04-18-2013, 03:04 PM
DougNuts's Avatar
I was under the impression that the A/C compressor wouldn't cycle if all of the R134a leaked out because the pressure switch wouldn't see any pressure. Maybe I'm wrong.
Old 04-18-2013, 03:12 PM
lilgcts-v's Avatar
well what i saw was the compressor was not spinning when the ac was off and then when i turned it on it was so im assuming thats not the issue im open to suggestions obviously.
Old 04-18-2013, 03:15 PM
Stone17's Avatar
How long does the compressor cycle for? 5 sec?
You can jump the pressure switch to turn on the compressor. I have done that before to check my compressor.
Old 04-18-2013, 05:42 PM
lilgcts-v's Avatar
i only checked to see if it would turn on and off, im at school and I'm trying to limit the amount of wrenching i do in the parking garage at the expense of looking like a tool hahaha i really appreciate any help i can receive for you guys, i will just have to sweat it until i get home when the semester is over and i have the appropriate tools.
Old 04-19-2013, 07:19 AM
RADEoN's Avatar
It's still very possible you have a bad compressor, a clogged orifice tube, etc.
Old 04-19-2013, 09:43 PM
meatyCTS-V's Avatar
We don't have an orifice tube like that... we have a thing that hangs off the side of the condenser with a dessicant bag and a small little screen...
-meaty
Old 04-20-2013, 12:36 AM
bigirishlt1's Avatar
Check the pigtail on the high pressure switch
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/1608121-service-ac-system.html
Old 04-25-2013, 05:41 PM
Sssnake's Avatar
See above. Mine was in bad shape (occasionally shorting) and causing issues. caspers has a pigtail for easy replacement.
Quick Reply: AC not working ?
