3bar SD tune??
Old 04-16-2013, 06:03 PM
MillsMotorvation's Avatar
Default 3bar SD tune??
Im upgrading my setup, and I have a 2bar SD tune now. Cant seem to Frost on the phone or email. Im thinking of turning to boost up at some time, and Im on 14psi now. Do I need 3bar to run 14-20psi? Anyone got a 3bar for HP Tuner I can start with? New setup 408/comp cam/GT91mm/60lb inj, and meth inj, TH350 trans, 2000 chevy turck ECM. Also what MAP sensor do I need, I think I have a Durmax one here somewhere. You can email it to me www.millsbernard87@yahoo.com
Old 04-16-2013, 06:12 PM
MUSTANGBRKR02's Avatar
PM Dsteck on HpTuners for a 2.5bar MAP sensor. Plug and play and like 85 I think
Old 04-16-2013, 08:50 PM
Will a 2.5 get me to 20psi? I was hoping for 3bar, thanks for the reply.
Old 04-16-2013, 08:59 PM
2.5 will get you to 22.5
Old 04-17-2013, 04:02 PM
Ok, thats good, what will the one I got now got to?
Old 04-17-2013, 06:30 PM
If its a 2 bar then 14.7 lbs
With the 2.5 bar you still run a 3 bar OS just the sensor only reads to 22.5lbs. It's plug and play which is nice so you don't have to cut or get any adapter for your harness.
Old 04-17-2013, 08:37 PM
Ok, thanks alot for replys!
Old 04-18-2013, 08:13 PM
LS1Tech Sponsor
Alvin@PCMofNC's Avatar
We use these... http://www.diyautotune.com/catalog/m...sor-p-161.html You can pick them up from any local auto parts store.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old 04-22-2013, 04:09 PM
Neumonic2002's Avatar
I know Steck has a 3 bar map sensor that is a high quality plug and play unit.
He sells them on Flea bay www dot ebay dot com/itm/121092185326
Old 04-22-2013, 04:30 PM
I didn't know that he offers the three bar also.
Old 04-28-2013, 12:26 AM
Is tthe 3bar plug and play, or do I need to get my tune changed?
Old 04-28-2013, 07:00 AM
Any upgraded Map/OS requires a tune
Old 06-17-2013, 01:42 PM
Thanks a lot!!
Old 06-18-2013, 01:31 PM
PowerAdder's Avatar
Off topic, hows that th350 holding up. What you got done to it? Building a twin 73 camaro has a th350 in it all rdy.
Old 06-24-2013, 11:33 AM
The trans is good, but the convertor cant hold it, dont go cheap on the convertor. I should of call Revmax.
Quick Reply: 3bar SD tune??
