DO i need more timing adjustment?
Old 04-17-2013, 03:01 PM
zurek30's Avatar
Default DO i need more timing adjustment?
I currently am running a 125 shot on a plate system and if i swap the jets out and go up to a 200 shot do i have to adjust the timing some more and if so what should i start with?
Thanks
Old 04-17-2013, 03:06 PM
HCI2000SS's Avatar
Yes you should. How much timing do you have pulled now? What mods are done to the car?
Old 04-17-2013, 03:18 PM
brandon@nitrousoutlet's Avatar
General Rule of thumb is 2 degrees per 50 hp you're adding. So a 200 shot you should pull 8* total.
Old 04-17-2013, 06:20 PM
fly boy_1's Avatar
What symptoms would show you need to pull more timing or can get away with less?
Old 04-17-2013, 07:16 PM
Dynospeed's Avatar
Symptoms - damaged plug or broke piston
Read the plugs. Always pull a little extra timing when unsure. Get the fuel correct then slowly bring timing in while closely monitoring frest plugs.
Quick Reply: DO i need more timing adjustment?
