Need help please with ignition please
ok got my motor put in everything bolted down ready to go but when i turn my key to my starter nothing all my lights work starter was tested good. I checked the wire from the ignittion to the small spot on the starter with the key all the way forward like your trying to start it and there is no power going to it at all i've tgried several different batteries and nothing all them were good no power to the ignition wire to the starter it was in neutral with neutral safety switch pressed. I really need help it's a 6spd i checked everything even traced the wire up to the dash and still no power the relay was clicking in the glove box and i tried swappin it with another and the same thing. fuel pump works when i turn key on and no security flashing. Please help me
