17x4.5 Front Runners with ABS
So hearing from other fbody owners you can not run 15" front runners with out it messing with your ABS system. I have the factory 4 channel ABS, and was wondering if running Racestar 17x4.5 would affect the ABS also? I would like to keep the factory ABS if possible.
The issue is not with the rim, but the circumference difference bewteen the front and rear tires. Too big of a difference in the roll out will cause issues, or at least the light to be on.
I have 15's on my car.
It's all tire size, if you run the same height tire all the way around you won't have any issues, sounds like your buddies are slamming on the brakes, causing the abs to kick in.
