what progressive, window switch ect....
Its ur guys nitrous direct port kit on the fast 102. 2 fuel solenoids and 2 nitrous solenoids. I just want to know what other stuff I need has in progressive, switch, timing to run the 150 shot. Buying the stuff from u guys
The NOS mini will control the system well. It will give you the window switch, TPS activation,time base progressive, trigger out put and control two stages.
http://nitrousoutlet.com/index.php/e...ontroller.html
The lingenfelter is a great timing controller. It will remove up to 15 degrees of timing. It has a 0-5 volt reference wire so that you can verify that it is removing timing. It also has a built in Two step.
Dave
Dave
