Are MLS head gaskets diff. from LH -RH side?
I bought the GM MLS head gasket set which includes both head gaskets (drivers & passenger side). I cannot see any difference between the two gaskets at all.
Also, both gaskets have "FRONT" marked on both side of one end. This means that depending on the way you turn the gasket, it can be used for either side. There is no "UP" marked on either gaskets.
Is there any difference? If so can you show on a photo?
