ignition key question
Old 04-19-2013, 06:44 PM
01 Vert ws6's Avatar
Default ignition key question
I am swtching my steering column because the tilt is way loose , I bought one today with a key , do I have to switch my ingition switch from the old column to the new column
Old 04-19-2013, 07:17 PM
flame's Avatar
Yes unless you do a vats relearn to program the new key code into the bcm
Old 04-19-2013, 08:06 PM
OhTwo's Avatar
I think that once the BCM is set for a specific resistance you can only do a bypass or use an ignition key with that same resistance. It doesn't need to be the original key as I've swapped my switch and had the new key cut to match the old resistance.
Quick Reply: ignition key question
