Are My Dyno Numbers low..???
Is my car a dog..?? It has a k&n cold air intake bbk 58 mm throttle body 1.6 rockers arms stock heads that are milled lt4 hot cam slp stainless mid length headers full borla exhaust msd wires and a 160 thermostat and a dyno tune by ion mad tuner it made 302 rwhp and 310 rwtq
Doesn't seem too bad for the mods for an auto.
Longtubes and headwork will help quite a bit. A stall will help your ET the most now though, but it may actually lower your rwhp.
OP, My setup is similar to yours and I've run a best mph of 107.93 at Union Grove with the hotcam, slp headers, LPE cai and stock rocker arms with a Madtuner tune. 120k miles. If spring ever shows up bring it up to GLD during the week for T&T and see how she does.
edit: If you're running the LT4 valve springs you might consider changing them. I was getting some valve float with the LT4 springs on the hotcam, swapped them out for some stronger springs and she revs much better now. Any signs of valve float on your dyno run?
What do you think it should be at if they seem a bit low to you..,?
I will when ever it get Warmer here.. I just wanted to know if people that have similar set ups what are they putting down to the wheels cause those numbers seemed low to me
