Corvette wheels on a third gen
It depends on the size which was already mentioned. The fronts usually need a 2 in spacer if going with a standard 4th gen size wheel, 17x9. If you have a stock rear you will also need a spacer of 2 in if going with the 17x9 rim. You could possibly use a 1.5 in spacer in the rear. If you have a 4th gen rear in the 3rd gen then no spacer needed for the 17x9 wheel since the rear is a total of 4 in wider.
