Squeak please help
Squeak please help
Alright all,
Have recently started hearing this really faint yet annoying sqeak from the right rear.
Not constant and usually audible just after letting off brakes,
Its a squeak squeak squeak, then nothing, almost a very very faint hum.
Tried pressing down on both rear corners,and wiggled tires but cant recreate the noise.
Any ideas, my gfriend thinks im nuts, but the noise is driving me mad!
Is this when going over bumps only, or when braking? If its over bumps, and when you push the car down when parked, it could be the sway bar brakcets or bushings. My z28 had a squeak that only happened when going over bumps, and i replaced the LCA's, rear shocks, and PHB and it was still there. Once i replaced the sway bar brackets and end links, the squeak was gone.
Now my ws6 has the same squaek from the front and rear, so im just buying a set of sway bars.
