tick master where does you pedal grab
Old 04-21-2013, 07:26 PM
spiro27's Avatar
Default tick master where does you pedal grab
just installed tick master. my pedal grabs at the top about half inch from letting off the clutch pedal. is this setup right. where should the pedal engage. do I have it set up right my stock pedal grabbed from just off the floor. with tick it grabs neer the top.
also installing new clutch soon does anyone know the torqe specs for arp flywheel bolts and pressure plate bolts.
thanks
Old 04-21-2013, 08:47 PM
Yun Gunz's Avatar
Mine grabs instantly off the floor with an LS7 Clutch.
Old 04-21-2013, 09:28 PM
SuperSport01's Avatar
Flywheel bolts are here: http://arpinstructions.com/instructions/330-2802.pdf
I couldn't find the arp pressure plate instructions.
Old 04-21-2013, 09:38 PM
AJG87's Avatar
That's interesting..
Old 04-21-2013, 09:43 PM
This isn't the first time I've seen arp's online instructions be different than the ones included with the fastener kit. Very interesting for such a reputable company.
Old 04-21-2013, 09:46 PM
AJG87's Avatar
That picture is a little old so they probably just update their torque setting.
Anyways this guy called them a year ago and got 85ft/lbs for flywheel and 45ft/lbs for PP.
https://ls1tech.com/forums/16090712-post2.html
Old 04-21-2013, 09:49 PM
^ sounds right IIRC.
Old 04-22-2013, 06:07 PM
spiro27's Avatar
thank for tq specs
my car has stock clutch still. upgrading to monster stage 3 very soon. anyone know where the tick mc sopsosed to grab/ingage top of travel or as soon as it lifts off the floor thanks for help.
Old 04-23-2013, 05:21 PM
Black 99 Bird's Avatar
Mine releases pretty low to the floor also.
Old 04-23-2013, 07:17 PM
3rdCoastPowerSports's Avatar
should release right off the floor if set up per ticks instructions. You can adjust it to release higher but tick advises against this due to the increased fluid volume flow and the potential damage to the slave cylinder.
Quick Reply: tick master where does you pedal grab
