How to scan a 95 lt1 w/ obd2 port w/ obd1 scanner?
Old 04-22-2013, 01:40 PM
Numba20's Avatar
Default How to scan a 95 lt1 w/ obd2 port w/ obd1 scanner?
I've got a 95 trans am. Obd1, with a obd2 port. A friend has an obd1 scanner with obd1 (square) hook up. I've found this...
Will this conversion method safely and effectively read and clear DTC's?
Old 04-22-2013, 03:16 PM
Numba20's Avatar
TTT... no one ever try this?
Old 04-22-2013, 03:17 PM
NewOrleansLT1's Avatar
Either try that or buy the proper adapter
Old 04-22-2013, 03:56 PM
shbox's Avatar
Sure, it works. It would not be on my website if it didn't.
Old 04-22-2013, 04:19 PM
Numba20's Avatar
I just linked it from google images I didn't even realize it was from your site. I'm sure since it's on there its safe to do as well. Thanks shbox!
Old 04-22-2013, 04:37 PM
96capricemgr's Avatar
the OBD1 scanners that are meant to flash the CEL will NOT work on the 94-95 cars. Does your friend's scanner have a display of it's own?
Old 04-22-2013, 08:47 PM
Numba20's Avatar
No, it flashes the SES light. And that's about what I was going to ask. The scanner is a 10 pin obd1 scanner and it has 3 prongs, which on a 10 pin connector would be A,B, and H ports I believe. So this probably won't work. Damn, I mean they just have to make it a wild goose chase to read codes?! I just want to drive to autozone, borrow their scanner and b done. Sheesh.
Old 04-22-2013, 09:05 PM
shbox's Avatar
What, you didn't see the big "shbox.com" in the middle of the pic?
Really, if you are going to work on your own car, you need a scan solution of your own. There are so many cheap options out there.
Old 04-22-2013, 09:07 PM
buy a cable and get the free "20 uses" download of Datamaster. You will find it such a great tool you will then gladly pay for the unlimited use of the program.
Old 04-22-2013, 09:13 PM
9-Second Club
Ed Wright's Avatar
There ya go. Works damn near as well for basics as my Tech2.
Old 04-22-2013, 09:41 PM
Numba20's Avatar
I tend to only see exactly what I am looking for and over look everything else I thought I recognized the yellow labeling though. Lol
Which route would u recommend?
I actually borrowed my sisters laptop (I have Mac) (she has windows) and downloaded data master. I opened the program and it looked pretty nice. A friend had a hypertech programmer which I was going to use his connector to the obd2 port, but the plug in the computer was different. I investigated different cables to buy as well, cheapest is about 60 right? How much is the full version of data master?
Old 04-22-2013, 09:44 PM
FSTFBDY's Avatar
https://www.moates.net/aldu1-and-cab....html?cPath=64
http://www.ls1lt1.com/forum/4th-gen-...gram-free.html
Old 04-22-2013, 10:18 PM
englundjd's Avatar
you can get tuner pro rt for free .. it has data logging capability its just not as fancy as datamaster
Old 04-22-2013, 10:50 PM
Numba20's Avatar
ill look into it. the only thing i want is to be able to read and clear codes. dont care about much else. i paid PCMforless too much money to have to figure out computer stuff myself. lol
Old 04-23-2013, 11:16 AM
Numba20's Avatar
His cable doesn't have the box... I'm guess it won't work for me? It's 20 bucks cheaper tho...
http://www.obd2allinone.com/sc/detai...item=aldlobd2u
Old 04-23-2013, 11:34 AM
englundjd's Avatar
yea, tunerpro rt is tuning and datalogging software. you can read/clear/disable codes
Old 04-23-2013, 01:55 PM
FormulaJoe's Avatar
I don't think you can clear codes with datamaster. If you can it's something I've never figured out lol. But I'm pretty certain you can't IIRC. A lot of people use datamaster to data log then use tunerpro to tune and/or clear codes. You can datalog on tunerpro also.
Also, a heads up in case you or anyone else has this problem, but the converter cable I got from Moates came with a shitty USB cord (the one that plugs from the computer to the serial converter). It would always cut in and out like crazy. I ended up using an extra one lying around my house and now my connections are clear as sunshine.
Old 04-23-2013, 02:05 PM
9-Second Club
Ed Wright's Avatar
You don't need any software to clear codes. Pull the PCM BAT fuse for a couple minutes.
Old 04-23-2013, 08:08 PM
Numba20's Avatar
Does moates have the only option for a cable, I've heard of AKM (or AMK or something like that.) I don't want a cheap that's going to give me problems just wondering if I've only got one option. I'd like to get this ordered tonight.
Old 04-23-2013, 08:13 PM
9-Second Club
Ed Wright's Avatar
I like AKM, but Andrew told me he stopped to work on his masters degree. Great guy. Very talented. Gonna miss him. :-)
Quick Reply: How to scan a 95 lt1 w/ obd2 port w/ obd1 scanner?
