ls1 single turbo kit
Where are you located?
What are you looking for?
Complete kit with everything or just the hot and cold pipes?
Are you wanting a shop to do the install as well or just fab the kit up for you?
Do you want stainless or mild steel?
Street car or track car?
If you just want some truck manifolds and a simple kit it wont be too bad if you know someone that can weld. But if you want something thats going to make good power, work with all the stock bs, and not having any issues and be done right its not too bad on the check book but its still not cheap by no means. Really depends on how crazy you want the hp numbers. Depending on where your located is going to determine who I suggest. But if you dont mind to pay shipping call up 417Motorsports, check out there website.
Huron Speed and On3 both make affordable single turbo kits. I think the Huron kit uses modified truck manifolds, and On3 uses some custom castings. Only the On3 kit offers a means to keep your AC, which is what led me to choose them since driving in AZ can become unbearable without it.
I haven't installed mine yet, but both kits have received positive reviews, although the Huron kit has been around a little longer. I think both are limited to T4 flanges w/3" downpipes and require an alternator relocation.
I probably got some of that incorrect, but anyways, those are the kits I narrowed it down to when I was looking around. On3 can ship pretty much same day, Huron needed a bit more time when I talked to them. Both were friendly and helpful when I spoke with them.
Call up Huron Speed! Best customer service around. And they do make an A/C kit. They can make you anything you want, just ask and they will make it. Nothing but positive experience's with them.
on3s kit is cheaper thats what im gonna be getting and then upgrading the bov gate and turbo i couldent see spending almost 2gs on just the pipes and inter cooler.
