has anyone purchased smartfire injectors
ok so I took a chance and purchased some 80# smartfire injectors from holyls1 right here on ls1tech, he was a vedor and now a formor vender. the 1st set had 2 stuck open and 1 didn't work at all. the second replacement set that holyls1 sent me where 96 low impedance injectors that I thaught where high inpeadance.
along the way this guy holyls1 sent a 2 bar map sensor for my troubles. both showed broken.
so anyways me ant the tuner desided to try the smartfire injector 80# again and barrowed a couple of known good one from a friend that was trashing his smartfire injectors. after some math we had to set the injector flow data to 44.8 to get it to run ad idle. the recommended setting of 83 wouldn't even come close to fireing the engine.
anyone have any info on these? im really really un happy and I have been very patient with holyls1. now im out 2 dyno tune visits and $300ish for the injectors.
log and tune files below. the tune is very crude because we couldn't do anything.
buick add 2nd fan 3.hpt
1st idle log.hpl
2nd idle data log.hpl
1st idle log.hpl
so anyways me ant the tuner desided to try the smartfire injector 80# again and barrowed a couple of known good one from a friend that was trashing his smartfire injectors. after some math we had to set the injector flow data to 48.8 to get it to run ad idle. the recommended setting of 83 wouldn't even come close to fireing the engine.
well just got done talking with holyls1. and I tested the ohms myself on the 96# injectors. and my tuner either don't know how to work a multimeter or just plain didn't test them. long story short the 96# injectors are high inpeadance as holyls1 stated they where to me.
now im going to get them flow tested at work which is Delphi automotive systems and be sure the 96 pounders. if theres anyone that can tell me whats up they can.
long story short. so far the 80s are not 80's there more likely 40's or 60's.
so thanks holyls1 for working with me even with this post up here.
alittle more info guys. the car dose idle fine on the so called 80's after toying around with the injecter flow data. and setting it to 44.8 across the board for idle tuning.
im going to send his 80# back and give the 96# a shot.
but at times your right. you get what you pay for
so far the guys been cool. i just got out of the hospital (cancer) and i haven't had the money to ship them back, so far hes been patient.
