Anyone here spraying a 200+ wet shot using a standard wet kit?
Just curious who's doing it and how things have gone for you and how you're pulling it off..
I was going to be spraying a dual stage 200 (100+100) using a standard wet kit until I can afford the D/P kit. The plan was to run very rich on the second stage to avoid leaning out the back cylinders.
I'm using a standard TNT F2 kit, for fuel i'm using the racetronix PNP kit with a voltage booster. I'm also using the old stlye NX maximzer, I spray 150 out of the hole, and add another 50-75 over the next 1 sec.
No problems yet, and this is on a stock bottom end.
