for use with any flip drive type system
Old 04-24-2013, 08:06 PM
ironhorse583's Avatar
Default for use with any flip drive type system
NOT PUTTING DOWN OR PICKING ON ANY PARTICULAR SYSTEM....JUST MAKING THEM BETTER.....
A couple cars we have put together have had issues with the alternator slipping while using the flip drive systems..We thought the problem was the 4 rib to 6 rib pulley the systems uses so we found a cure..
For the IW balancer we cut 2 extra grooves in the balancer. Then cut 2 extra grooves in 4 to 6 rib pulley now making it 6 rib to 6 rib and added a ZR1 AC compressor.
For the ATI people we machine off 1 rib then add material using an interference fit (.005) then weld..
i would like to offer this to anyone who is interested..
Attached Thumbnails for use with any flip drive type system-img_4194.jpg   for use with any flip drive type system-img_4197.jpg   for use with any flip drive type system-img_4195.jpg   for use with any flip drive type system-img_4196.jpg   for use with any flip drive type system-img_4200.jpg
Old 04-24-2013, 08:39 PM
Firehawk441's Avatar
Nice job. How much are the ZR1 A/C Compressors, and how much for the machine work to the pulleys?
Old 04-24-2013, 10:23 PM
u have a pm sir
Quick Reply: for use with any flip drive type system
