1995 z28 best way to replace evaporator core
Old 04-26-2013, 12:45 AM
95_Z-28_runner's Avatar
Default 1995 z28 best way to replace evaporator core
im going to overhaul my whole a/c system and was wondering the best way to remove my evap core. any suggestions?
thanks
Old 04-26-2013, 05:08 AM
Moderator
BizZzatch350's Avatar
When I did mine the dash was out and I had a lot of room, I've done the heater core with the dash in. With the heater core out it may be possible to swap it with the dash in just be kind of a pain. It wasn't all that fun with the dash out. I had to attach the expansion valve to the evap core and put it in the car that way.
Old 04-26-2013, 06:56 AM
DAVE00's Avatar
Neil, why would you have to attach the Expansion Valve to the EVAP core first? That part is probably the easiest to get to from under the hood near the firewall? Two hex bolts and remove the hp and lp lines and she's out.
Old 04-26-2013, 08:00 AM
Moderator
It came off that way which was simple enough but for what ever reason wouldn't go back on right. I may have not had the evap core correctly positioned or fastened right causing it to move or some thing. Not sure. The only other pain was putting that stupid bracket on that goes on the back of the compressor, that was kind of a pain.
Quick Reply: 1995 z28 best way to replace evaporator core
