looking for a company to spec cam
I have another mustang coupe that I put a ls1 in, but this time I went carbed. The car has a FTI 3800 stall with a th350, victor jr intake, 750 proform carb and im running a msd 6010 box. I want to get a cam speced specifically for a carbureted ls1
I am confident that Martin can wring all the HP out of your LS engine. To be honest I had Martin spec a cam for my mild setup and he scared me away with his duration numbers. I gave Bullet a call and Tims first question was "how much vacuum do you need"! That was what I needed to hear from my cam grinder. All our numbers were a result of 16" of vacuum and the fact that I had some really good springs in place on my heads.
I feel that Martin can do the numbers and get you where you want to be in a max effort combo and I have huge confidence in Bullet Racing as well.
To me , I think you need to do your research and KNOW what you are looking for in a cam, then let one of the pros tweak the specs to get the right grind for YOUR setup. Good Luck!!!
