Stalled 4L60e
Old 04-28-2013, 01:40 PM
BR02SS's Avatar
Default Stalled 4L60e
have a yank 3600 in my 02 Camaro ss but I still cant seem to get a better 60ft time then a low 1.8. The car has stock suspension,cam,headers and drag slicks. Any suggestions??
Old 04-28-2013, 01:47 PM
Blackbird-WS6's Avatar
are the tires hooking? what rear gear?
Old 04-28-2013, 02:44 PM
lemons12's Avatar
Change the converter.. I see a lot of yank 3600 60' in the 1.7 range.
Old 04-28-2013, 03:24 PM
JustAFooL's Avatar
Yank is a great converter but seems their 3600 doesn't perform as well as others sometimes. I absolutely love my 4k..
Old 04-28-2013, 06:51 PM
Footlead's Avatar
My Circle D 3200 budget convertor does that on DRs.
Old 04-28-2013, 07:59 PM
BR02SS's Avatar
Yeah they are hooking it seems. and whatever the stock gear is I just bought the car like it sits and they said it had a yank 3600 in it.
Old 04-28-2013, 08:07 PM
greenvortec97's Avatar
find the gear ratio and report back... also give us the full modification list of everything on the car as well as tire size
Old 04-28-2013, 08:09 PM
BR02SS's Avatar
What converter would you recommend for me to still drive it on the street and track.
Old 04-28-2013, 08:45 PM
Moderator
mrvedit's Avatar
If you have the stock 2.73 rear, nothing is going to help.
As mentioned above, determine the gear ration and let us know.
Old 04-28-2013, 09:43 PM
BR02SS's Avatar
3.23 gear ratio
Old 04-28-2013, 09:53 PM
lemons12's Avatar
Ptc 3600-4000 depending on future plans.
I would need to know 100% full mod list and info about passes before i said 100% the converter swap would fix the 60'.
Old 04-28-2013, 10:20 PM
BR02SS's Avatar
The first pass went 12.62 with a 1.89 60ft time that was racing with the car in overdrive.
but all of my passes have been 1.8 60ft times. the car doesn't seem to be spinning and it launches right around 3000-3200 but when you let off the gas and your just coasting the car does this strange bucking. but only when your coasting.
the mods are torquer v2 cam unsure of heads think there stock, yank 3600 stall, pacesetter headers ORY magnaflow muffler, trans cooler, hoosier quick time pros 26in tire, has a fast 92 on it but hasn't been tuned for it yet
Old 04-28-2013, 10:33 PM
lemons12's Avatar
Get a proper tune.. Take it to the track... Let me know when you get a clean pass after that.
Old 04-28-2013, 11:08 PM
BR02SS's Avatar
Vengeance has tuned the car but that was prior to the fast 92 going on. The car surged real bad when I first got it so I took it over there and they tuned it then.
Old 04-28-2013, 11:12 PM
SF 1HOTLS1's Avatar
I went 1.6 consistent on motor with the mods in my signature. Its a good converter imo. I have a whole new setup tho with an FTI. no new track times. Its ok just a little tight. Plan on sending it back to be adjusted a bit.
I also cut a 1.5 60 foot with the yank 3600 on spray.
Some 373s will wake it up for sure. and a torque arm man.
Old 04-28-2013, 11:23 PM
lemons12's Avatar
Did vengeance fox the issues?
I cut 1.50-1.52 short times barely spinning at 3500# with 36xrwhp.. Ptc 4000
Old 04-29-2013, 12:43 AM
BR02SS's Avatar
Like I said they tuned it and fixed the power surge but someone told me that when the car is coasting and it starts jerking it could be the torque converter also. I'm gone call them tomorrow.
Old 04-29-2013, 12:57 AM
lemons12's Avatar
In that case.. ptc 3600-4000.. Bucking is 95% of the time tune related.. Gears/cam/converter selection can as well. It can almost always be tuned put though.
Old 04-29-2013, 01:23 AM
BR02SS's Avatar
Thanks for the help. I'll let you know what happens. What all is done to your car what kind of times do you see out of it.
Old 04-29-2013, 01:33 AM
lemons12's Avatar
I ran 7.2-7.3s @ 95 1.50-152 short time barely spinning or so with the old 346 combo.. 3500# 2200+da nitrous tune.. 226 cam ls6 intake ported milled 317s ptc 4000. Real budget friendly setup but it performed well.
The current combo is a 370 lq9 based build.. Ls3 top end.. ptc 3500.. 200 shot.
Im looking for low 6s@110 or so on 200 granted the drive line holds up.. Once i get a new trans and rear ill move up to the 300.
Quick Reply: Stalled 4L60e
