2006 T56 from a C6 TO a 2000 C5 - direct fit?
Old 04-28-2013, 03:24 PM
BossV8's Avatar
Default 2006 T56 from a C6 TO a 2000 C5 - direct fit?
Hi,
I need to change my transmission on my 2000 C5. It's a Standard 6 speed manual and I have a 3.90'stage 2 diff from RPM on the car.
I have found a brand new C6 T56 from 2006, still in its box.
Would it directly fit on my car? I want to keep the rear diff.
Thanks.
Old 04-28-2013, 04:39 PM
jmd
jmd's Avatar
Mainshaft spline and tailhousing casting need to be the same. Some 2006 mainshafts were 27, some 30 spline. I don't know how long they used the early casting.
Old 04-29-2013, 02:25 AM
BossV8's Avatar
What should be the spline to be compatible with my C5? 27 or 30?
Thanks.
Old 04-29-2013, 10:02 AM
redbird555's Avatar
27 spline
Old 04-29-2013, 01:43 PM
BossV8's Avatar
The seller tells me 26 spline on entry shaft and 27 spline on out shaft. I am not sure about the wording as I am French.
Does it mean it is a similar transmission as a C5 (except for ratios)?
It then would be a direct fit.
Old 04-29-2013, 02:23 PM
jmd
jmd's Avatar
Post
Quick Reply: 2006 T56 from a C6 TO a 2000 C5 - direct fit?
