FULLY BUILT 6.0L LQ9 engine w/ oringed block and head
Category: Engine - Complete Motors
Price: $8000
Location (State): NC
Item Condition: Brand New
LS Engine?: Fits LS Engine
Eagle 3.622” forged crankshaft
Lunati pro billet 6.125” H beam rods w/ ARP 2000 7/16” bolts
Wiseco 4.030” 1.110 20cc rev dome w/ lateral gas ports forged turbo pistons C&A dura moly rings
Federal mogul 152M main bearings
Clevite cb663 H rod bearings, dura bond cam bearings
Billet main caps installed on 3 axis CNC w/ ARP studs
Machined block and heads for ARP ½ studs
Cam motion custom ls1 camshaft
Roll master double roller timing set w/ Torrington bearings and nitrated gears
LS1 oil pump ported & shimmed
Crane hyd. Roller lifters ls1 #10530-16
SCE Titan copper head gaskets for ls1
ETPerformance 245cc CNC ported cylinder heads w/ Ferrea 2.080”
Int. 1.600” exh. Valves, manley nex tek dual springs good for .650” lift. Titanium retainers, machined locators and locks
Combustion chamber 72cc
Ls1 comp cams push rods
Crower shaft mounted rockers
o-ring block/ receiver groove heads
also comes with: LS6 valley cover, valve covers with spacers, oil pan with -10an fitting mounted, oil pressure sender, cam, crank, oil level sensors, LS6 head coolant tubes, knock sensors with harness
Engine has under 300 miles on it. it is being broken in on Amsoil break-in oil.
Price does not include shipping or paypal fees etc.
