o2 sensors close to header collector throwing off a/f
I recently installed pacesetters LTS on my car and i started it and its running pig rich when it gets hot? i didn't order the y pip yet but will that throw off my oxygen sensors running open headers?? the o2s are close to the end of collector. and i believe there not getting hot enough and there seeing fresh cold air at idle when hot.. because collectors make sorta a vacume correct?
Thats kinda what i figured was happening thank you for the quick reply. what do you guys use to connect the y-pipe to the headers? i know there slip fit. 3 bolt flanges or those wide band clamps?
I have slip fit exhaust and use some wide clamps that i found at car quest
