Problem getting decal residue off.
I've taken off these stripes I had on my car. I used a heat gun and the vinyl came off easy but the glue will not come off for the life of me. I have tried wd40, goo gone, and heat with no luck. This stuff will not even budge. I scrubbed it for about 2 hours until my hand went raw lol There really has to be an easier way!
can try turtle wax bug and tar remover it takes alot of applications but it got the glue from my z28 badges off after bout 5 car washes of using it didnt do much scrubbing just sprayed it on each time i washed the car till it was gone.
No. Modern clearcoats are pretty damn tough. When I detail a car, I use lacquer thinner, and or mineral spirits to get the road tar off the bottom of the car. Enamel reducer is the best for glue residue because it softens it up enough that you can "roll" it off with your fingers. Lacquer thinner eats the glue off, but it makes it slimy and you use a lot of shop towels to clean it off.
If you decide to use acetone or lacquer thinner then I suggest you have the water hose in your other hand. That stuff is pretty harsh and I wouldn't want it on my car's paint a second longer than it needed to be.
I've found great luck with a decal eraser. It removes the decal/stripe/glue and all with no paint damage when used properly. I have used it on fiberglass boats, motor cowls, steel body panels, and all sorts of other things. If a small amount of residue is left, a paint prep solvent will remove the rest. Here is the type I'm talking about. I haven't used this particular brand, but at least you know what to look for. I had used the one made by 3M.
http://www.eastwood.com/vinyl-eraser...FVEV7AodhmEASg
careful with solvents if factory paint ur fine....some repaints not so much..just dont soak it an u will be fine with thinner ect.. then wax it to replace shine
