how to remove crank keyway
My keyway needs to be replaced and its not coming out. I had a visegrip on it but it doesnt move. Can i heat up the crank and pull with the visegripor what is the trick?
No there is a big difference from when I was removing the crank hub I had to chain the puller to stop it from spinning. Now I was able to tighten the damper bolts with some force and didn't feel like the last time when I changed the opti. The crank spun easier. a4
