Pontiac GTO 2004-2006 The Modern Goat
2005 gto vibration
Old 05-03-2013, 03:43 PM
brawley_andy's Avatar
Default 2005 gto vibration
hey i have a 2005 gto with a t56 has a one piece drive shaft that was installed before i bought it. when i get up to 80 mph it gets a bad vibration that feels like its coming from the rear. when it starts vibrating it also starts leaking trans fluid out of the tailshaft. if i keep it under 80 it wont leak. any suggestions here would be awesome
Old 05-05-2013, 01:31 PM
xBoostx's Avatar
The one PC drive shaft, solution.... the OEM Two piece drive shaft or "Farbon Kiver" and new tail shaft seal.
Old 05-05-2013, 07:52 PM
Its had about 6 new seals the one that's in it now is from tremech
Old 05-05-2013, 08:44 PM
Slo4's Avatar
I had the same problem with my last GTO except it would blow the seal at 130+mph. I would put a hendrix 2 piece in.
Old 05-19-2013, 09:19 AM
would a bad tailshaft bushing cause it to have a vibration?
Old 05-19-2013, 09:43 AM
04gto5.7's Avatar
I'd make sure the Driveshaft is still in balance.
Quick Reply: 2005 gto vibration
