Can this shifter be swapped out?
Tearing down my car for clutch install,it looks like the car already has a b&m installed in it?
I already purchased a Ralco shifter,but now im concerned I won't be able to swap this out since the (b&m?) has its own aluminum cup and plate for the center section.
This shifter that's been in the car sucks,can the parts be swapped over for a new shifter or am I stuck now?
Here is a pic of it:
Someone explain why you would put the nuts on top & bolt on the bottom? If it backs out (shouldn't with those nylon nuts. . . but), the bolt falls & you got nothing holding it in place. Flip it & you've still got the bolt in there, but with a lot of slack.
The bolts were positioned that way because this b&m is threaded on the top,so it bolts from the bottom,nuts were there to just further secure it.
I'm just not a big fan of it,it's extremely sloppy and loose inside the center section.
Although upon removal of my trans,the 2 shifter bushings were shot to hell and in about 4 pieces,literally falling out lol.
Need to tighten all these bushings up in here before I install everything.
