Some boost calculation help needed
Just upgraded to a sdce setup on my 99 formula. I was running a 6" crank and a 3" pulley
Sd concepts told me that to run 6ish lbs of boost I need to get a 4.25" pulley. My car has just a ls6 intake an Mac mid headers.
Now doing the math. I'm now spinning the procharger slower.
6 rib setup is 49200 at 6000
8 rib setup is 41964 at 6000.
Now was I getting so much belt slip that this new setup will net me 6 lbs? Or did sd screw up? Bc now I need a new pulley and a new belt.
I don't have a boost gauge installed. Dumb I know. I've had it sitting on a shelf for two years. Just didn't want an. A pilar pod so I didn't know where to put it.
Anyone have any ideas
And also can I change a pulley with the procharger still on the car.
And if I change pulleys I'm going to a 3.4 will my belt be good?
UNDER PRESSURE MOD
So what crank pulley are you running? If it's the ATI 8-rib hub, it's 7.65", so take that into account for your calculations.
Also, which blower? Is it a P1 or D1?
I'm not sure about the SDCE bracket, but I know with my Aster bracket, I need to unbolt the blower and part of the bracket to remove the belt. If you go from a 4.xx to a 3.4" pulley, chances are you need a smaller belt.
