stock ls2...change rod bolts like the ls1's?
picking up a freshly rebuilt L76(ls2) just wondering if i should change the rod bolts like everyone does in the ls1. its a stock bottom end...gonna have ported 317 heads, ported ls6 oil pump,HD timing chain, brian tooley valve spring kit, hardened push rods, and tick turbo cam. running a master power t76 turbo.
anything else i should do while i have the short block by itself.
