changed oil pump....
I finally got around to changing my oil pump and o-ring and after a long ride noticed the pressure roughly in the same area as before. It reads below half and just above 1/4. On a cold start it is just over half. When i'm driving at anything over 1 000rpm the pressure is fine. Only at idle does it go lower. I'm worried about summer and traffic and the pressure going even lower. I hope it dosen't. Have any of you have a similar problem?
